Rule of thumb for beam tilting for a reflector antenna with off-focus feed
I'm looking for a rule of thumb for the beam tilting of a reflector antenna when the feed has an offset relative to the focus. So basically something like focal length+feed offset equals x° of beam tilting. I'm assume that the exact tilting depends on illumination etc., but for the first rough design it would be very useful to have a rule of thumb.
Thanks a lot in advance,
RE: Rule of thumb for beam tilting for a reflector antenna with off-focus feed
For small offsets, that should be pretty much it:
offset in mm divided by focal length in mm = angle in radians
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Thanks a lot for answer
