"linking" override positions (constraints) to other assemblies
Hello Guys,
We have the following issue.
A component in an assembly is constraint to a certain position and other components.
When this assembly is used as a subassembly that component will get a Position Override to change the components position for the main assembly. (see attached picture)
Question is now, can this position override (and with that the new constraints) be copied if the subassembly is applied into a new Assembly such that it automatically assumes the new override position?
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
