NX9: Edit appended Text
Hi Guys,
In NX8.5 we had the procedure to change from a dimension the value and change it to a letter which was then referred to in a table (Tabulated drawings)
Procedure for this was to;
Is this as designed? If so, any other suggestions onhow to accomplish this? New functionality which we are not aware of?
- Rightclick on dimension
- select "edit appended text"
- select dimension value (it appears in text field of edit appended text menu)
- Substitute dimension value for Letter (system gives a warning you are about to change it, select ok)
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
RE: NX9: Edit appended Text
In NX 9.0 procedure is:
1. Select dimension
2. RMB - Settings
3. Text - Format
4. Override Dimension Text
5. Click Icon "A"
6. Change text.
Best regards
Michał Nowak
Works fine, but a more cumbersome way of working...
NX8.5.3 / TC9.1.2
HP Zbook15
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
And the Journaling would be nice indeed...I'll try 2morrow :)
NX8.5.3 / TC9.1.2
HP Zbook15
www.nxjournaling.com
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
The cool thing is that one can revert back and forth by the steps that MANox describes.
Tomas
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
True dat. I'm not sure if the above quote was in response to my comment; but if so, I'd just like to clarify:
My previous comment was for anyone looking to convert a manual text dimension back to automatic text in NX 8.5 or lower. I don't remember offhand, but I don't think there is a checkbox option in the settings for it like there is now in NX 9. I kind of stumbled across the "convert to automatic" option when working in NX 7.5 (or maybe it was 8). I thought there must be a way to convert a dimension back to automatic text, but the method wasn't as obvious before NX 9 (not as obvious to me, at least).
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
