how to invoke a part from a Product by using VBA
i am working on an assembly. I want to switch to part workbench by using VBA.
Same things we can do by double clicking on the Part entities in an Assembly.
How can i do it by using VBA?
RE: how to invoke a part from a Product by using VBA
From the assembly level, you can find the object of the part you want to work with and create/modify/delete object with no problem.
Why do you need to activate a part level workbench?
Eric N.
If you had an assembly loaded and you wanted to do something like StartCommand "Publications", you would need to be active on a part or the publications would be made at the assembly level.
To place a part in edit mode, add the part to the selection then change the workbench to Part Design or GSD.
CATIA.StartWorkbench("PrtCfg")
thank you landman363.
I was looking for same. It solved my problem :)
one more question... where can i find argument of startworkbench.
like "PrtCfg" in above example.
Unable to find the same in V5automation.chm file
thank you very much ferdo
You're welcome...how about a starcheershourglass
