Cement Modified Soil
I have a project where we are constructin roughly 100,000sf of new surface parking. The soils underneath are garbage up to 10ft in depth so undercutting and replacing with shot-rock is not a good economical solution. Does anyone have a good specification for using cement modified soil? I've heard this works really well for this type of application.
RE: Cement Modified Soil
f-d
ípapß gordo ainÆt no madre flaca!
assuming you do it right with normal, low w/c ratio, shrinkage cracking should not be an issue
cement treated base
soil cement for paving
lime stabilization
http://www.limestabilization.com/
