Default seettings on ProE opening!
Hi
Was wondering if any one can recommend a good tutorial on setting up the Config options file for proE?
Ones I have had to change e.g.
Angle of projection to First angle
decimal places displayed when dimension is annotated first so that its to one decimal place.
How do you set it so it reads this file on program boot up!
Where can get a list of the config options explained?
regards
paul
RE: Default seettings on ProE opening!
View related options are part of the drawing file and can be read in from a .dtl file.
The other one can be driven by a template part; usually as part of the sketcher environment.
Google is your friend on this.
You could also try the PTC Community site.
You don't say what version you are using. I've attached all the config options for Creo 2. There are multiple places to put config options, you need to read the installation guide. Some options are set as company standards that can not be changed, others are set by projects and others are set by user preference.
