Longitudinal seam orientation in pipelines
Gentlemen - Virtually all client specifications call for the long seams in pipeline to be in the top quarters of the pipe, offset (not aligned) at girth welds. Bends have the seam at the neutral axis. What is the reason for not having the seams in the bottom quarters of the line?
RE: Longitudinal seam orientation in pipelines
BS 4515-1:
"When a pipe with one longitudinal seam is used, this seam shall be located within the top half of the pipe circumference and the
longitudinal seams of adjacent full pipe lengths shall be offset by an angle of approximately 90º or by a circumferential distance of approximately 250 mm, whichever is the smaller."
The engineering and corrosion points of view are:
1. Fracture arrest of cracks initiated in the weld zone of the seam
2. The greatest accumulation of liquid water as a corrodent would be expected at the bottom of the pipeline and the seam, being a different material to the pipe body, might give rise to preferential corrosion
If I have to choose between putting a weld on the neutral axis of a bend and putting it on the bottom of the pipe (i.e., in a situation where the neutral axis would be on the bottom of the pipe and you can't flip it) I will put the weld on one of the higher stress planes. This isn't often a problem with shop bends (because you can just flip the bend over), but for compound field bends that can get complex it can be a big deal.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
Piping Design Central
1. Ease in visual insopection and NDE of long seam during integrity digs.
2. Seams in the bottom quadrants are more susceptible to damage caused by poorly prepared ditches (read: rocks) during lowering in and subsequent backfill. With other qualifiers, ASME B31.8 specifies "Dents that affect ductile girth or seam welds are injurious if they exceed a depth of 2% of the nominal pipe diameter..."
Each of the above especially relevant for A.O. Smith low frequency longseams.
