Adding Points to a Studio Spline
I am currently on NX8.5.3.3
It has been more than a couple years since I worked with studio splines, and it seems like I lost my touch with them.
How do I add a new point to a studio spline that will be between two existing points ?
I can add a new end point easily but that's it.
RE: Adding Points to a Studio Spline
This will allow you to select the spline itself in its interior to add points (could also select a spot along another curve or edge but that would create a new endpoint as you are experiencing now)
The Enable Snap Point icon toggles are the key
You can have, for example, Point on Curve highlighted and Existing Point highlighted
You could click on the spline somewhere in it's interior to create a new interior point, then immediately drag it onto an existing point
Hope this helps.
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
