Inflation of 3 tryton balloon
Hi Guys,
I generated Tryton balloon geometry and meshed them with shell elements.
I am using Abaqus/Explicit to inflate the balloon. I am applying uniform pressure to the internal walls of the balloon with a linear amplitude curve from 0-1.
E=920 MPA
Poisson Ratio=0.4
I see a recoiling behavior, which can also be interpreted from Kinetic Energy values after each increment.I am attaching a series of images,in the increasing order of step time.
Link
Is it because of the fact that i am applying pressure in an impulsive way?I tried to do the same simulation for a step size of 10, the recoiling effect was dampened but the balloon was still recoiling.
I would like to know what can be the potential reasons for this.
Any suggestion or idea would help :)
E=920 MPA
Poisson Ratio=0.4
Link
RE: Inflation of 3 tryton balloon
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
Given the limited info you provided I would suggest the following:
1) Use membrane (M3D4R) elements instead of shell elements.
2) If you are trying to perform a quasi-static analysis, remove any damping or mass-scaling and adjust your loading rate so that kinetic energy remains <5% of internal energy for the duration of the analysis. Internal/kinetic energy are reported as history outputs by default for explicit analyses.
3) Use a smooth step amplitude for your pressure load.
4) Check your units - your equivalent stress values look very low.
5) If you just intend to model a balloon, use standard/implicit.
Good luck,
Dave
