about cbr test
about cbr test
about cbr test
hello
what is the purpose of using a filter paper in cbr test and is it correct to use the modified proctor molds (152 mm dia 115 mm height ) for cbr without a spacer disk since it gives same sample volume ?
RE: about cbr test
If you don't use the spacer disks how would you place the surcharge weights during soaking or during the test (pushing the plunger)?
RE: about cbr test
i can use the collar
