Windows error 2 occurred while loading the java vm. There are problems at install license server.
RE: Windows error 2 occurred while loading the java vm. There are problems at install license server.
Oh Oh......you broke it.
Proud Member of the Reality-Based Community..
To the Toolmaker, your nice little cartoon drawing of your glass looks cool, but your solid model sucks. Do you want me to fix it, or are you going to take all week to get it back to me so I can get some work done?
do you have a copy of 64bit Java installed?
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
Hi. PhoeNX
I have installed java 64 bit, but the symptoms are the same.
I have the same problem.
I'm running Windows 10 LTSB N also.
Try installing the latest version license service (I think it's 7.2.0) that you can download from GTAC.
I am using Windows 10 and the license service (latest version) works with no trouble at all.
Anthony Galante
I had the same problem, running windows10
I downgraded my java version from 8.6 to 8.51, which seemed to do the trick.
That did the trick MagnusBS!
Thanks.
