Can this be made by CNC?
So I thinking of trying to machine this out of aluminum, it is a dock for a magic mouse made by apple. Approx 5" long by about 5" long by about 3" wide by about 1.5" tall. The groove inside I guess is the question. i know the rest can be made with CNC. I dont want to cast if I can avoid it.
RE: Can this be made by CNC?
B.E.
You are judged not by what you know, but by what you can do.
Proud Member of the Reality-Based Community..
To the Toolmaker, your nice little cartoon drawing of your glass looks cool, but your solid model sucks. Do you want me to fix it, or are you going to take all week to get it back to me so I can get some work done?
If you wanted some weight-reduction, or a pocket to include some electronics, you could mill that into the bottom side before flipping it over to do the contouring on top. Easy part.
_________________________________________
NX8.0, Solidworks 2014, AutoCAD, Enovia V5
*edit* duh, iphone. Should have remembered.
There are casting options with pretty good accuracy (not CNC good but reasonable) that give good surface finish, low porosity and reasonable tooling costs.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Check out my buddy Bart giving his spiel if you want https://www.youtube.com/watch?v=sFl5VEecm_g - he over sells the 'not needing draft' aspect a bit in my opinion as for certain features you do still need it to get good yield but it is less demanding than many other casting & molding processes.
(Bad news is because this was 2013 you don't get to see either of the parts he's made for me on his display stand
