Stiffened Plate output
Hi everybody,
FE is not all about piece of art with nice colors, but still! I've got a plate stiffened with beam, and I would like to now if it is possible to display stress on the beam as well as on the plate?
I've attached a screenshot to illustrate the problem.
Thanks a lot fir your help!
Cheers,
RE: Stiffened Plate output
Yes, starting in FEMAP v10.3 (or maybe v11), in the "Select Post Processing Data" window (the "{}" button) you have the "Multiple Contour Vectors" button, which is thought out for this: plotting results on different types of elements.
Be advised though: if you select 2 vectors on the same element type, FEMAP won't automatically do the max of the two.
So in your case I suppose you would select something like "Top Von Mises stress" for the plates and "End A Max combined stress" for the beam.
Do not do the following:
1) selecting both Top and Bot plate VM stress: FEMAP won't do the max. For this you need to select the "Double-sided Planar Contour", which WILL do the max operation
2) selecting both end A AND end B max combined stress: again FEMAP will not do the max operation, it will only display the first one.
AP
most FEA will calculate beam stresses, at the extreme edges, at the centroid. but maybe you can't plot with plate stresses.
else hand calc ...
