How applying load on nodes
Hello there,
I really need you to help me because it's part of my Master's dissertation that is due next month...
So, I would like to know how I can select several nodes and apply a force on them.
I guess I need to develop a set node first but I don't manage to select several nodes.
Could you tell me how can I do this simple task.
PS: I wanna use nodes from shell element
Thank you, I really hope hearing from you soon guys
RE: How applying load on nodes
I solved the previous issue by using a segment and defining the nodes used to create the given segment.
Now, I am facing a new issue being that after creating the segment, LS-Dyna tells me that the segment doesn't lie on structural elements.
I don't understand as I am using the nodes from the geometry.
Could you please help me guys.
I hope hearing from you soon
Many thanks
