NEON LIGHT NVIDIA K620
after installing K620 neon light option disappeared. can't find any setting in NVIDIA manager. reseting catia setting doesn't work.
guys do you have any ideas how to get neon light back?
Thanks in advance.
Cheers.
Thanks in advance.
Cheers.
RE: NEON LIGHT NVIDIA K620
I have NVIDIA also in my laptop and after last driver update I noticed I can't connect a projector...it seems last update for NVIDIA is not the right option...so, going back to a previous version solved the issue....maybe is something similar?
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
surfaces. i don't have any free form analysis tools like zebra shading so I've found neon light to be useful thing.
find it strange as I assume K620 is an upgrade from no CAD video, so you should have more...
what video card had you before that?
it's time to disturb Intel
so it's not graphic card issue. jeez how to get neon light to work.
the guy from dassault told me to remove sp3 and then install sp3 back.. doesn't works. i'm on v5r25 sp3.
will see if hf008 will help me.
you should have that in GSD
i will look at new nvidia driver so far 353.62 is good in V6 2015x with K2000
