Conductivity as a method for determining the solute concentration on apolar solvent: is it possible?
I'm trying to find a relatively simple method for determining the concentration (up to at least 1% of accuracy) of an organic compound in methylciclohexane from a liquid-liquid extraction in order to provide standard crystallization conditions downstream (many recicle streams from one batch to another turns this crystallization in a living hell; eliminate then is out of cogitation).
I already have conductivity meters that act separating the organic phase from the aqueous. The range of conductivity is very broad (13 to +1000 mSiemens), and the organic phase have a conductivity around 19 mS on average, oscillating between 13 and 26 mS. An oscillation of 3 or even 6 mS can be observed even on operation stops, so i know for sure that the conductivity meters calibrated for this rangeare could not be used to build a curve correlating the concentration to the accuracy desired.
The question is: it is a fact that even apolar media presents some conductivity, and this conductivity is a function of the species and their concentration in the media (the temperature is kept constant), so a conductivity analysis calibrated for a smaller range (like 0-30 mS) would have the sensibility for detecting solute small concentration variations? I could request a lab study for creating a curve fiting this data if it correlates to concentration in a significative and measurable way.
If not, what other methods do you suggest for measuring organic solutes concentrations on organic solvents in industrial equipment?
Thanks.
Thanks.
RE: Conductivity as a method for determining the solute concentration on apolar solvent: is it possible?
Are there any other solutes / contaminants in this MCH?
About other solutes, only in small amounts. The dried up product minimum concentration is 97%, but yes, MCH has some minor contaminants.
I will search for those references.
