Bolt Length NPS > 24"
Where i can find the bolt Length for connections NPS > 24"? , my project works according to ASME B16.5 for NPS < 24", and ASME B16.47 Series B for NPS >24".
In the ASME B16.5 i can find both the Bolts lenght calculation formula and the finale bole legth
but in the ASME B16.47 there is only the Bolt Length calculation (Lsb), I need this value to prove tha my calculation is correct.
Please Help
RE: Bolt Length NPS > 24"
Chivaslive21, not aware of any tabulation. Suggest you get a co-worked to check your calculation.
Mike
Thanks for your support SnTMan, i will do that
