foundation settlement problems
I have some foundation settlement problems under some smallish lightly loaded spot footings and under some very large heavily loaded mat foundations. The settlement in both cases seems to be mainly caused by acidic runoff seeping through the soil and dissolving the underlying soils (and probably some soil transport as well). I believe the causes of the settlement have been taken care of for now, but I would like to shore things up for future problems. What are the most common remediation options for stabilizing the soil and the settlement? The couple options I know of are grout injection and installing deep piles adjacent to the mat (or maybe through the mat) and tying them into the mat. Are there other options? Are the options different based on the spot footings versus the large mats?
RE: foundation settlement problems
What is the subsurface profile?
If your groundwater is at 8', the pH of the groundwater at much lower depths is not likely to be significantly lower than normal.
Do some pH profiling and sampling for future efforts.
Do you know the acid(s) involved so that a neutralizing agent could be injected? If this is possible, it would have to be done under and away from the structure as side leaching will occur with time. This could be a periodic maintenance process until the soil stabalizes.
Mike McCann, PE, SE (WA)
You might consider foam injection into the soil.
