Chlorine Diffusion In 10 inch Pipe
Supposed I have a tank full of chlorinated water with 10 ppm free chlorine in it in the form of Ca(OCl)2. pH is 7.5.
there is a 10 inch pipe connected to the tank
how fast in m/hr will the chlorine diffuse into the pipe?
is there a way to calculate a linear diffusion rate in the pipe?
regards
rami
regards
rami
RE: Chlorine Diffusion In 10 inch Pipe
As posted, it is difficult to formulate a response.
the tank is a large one 2000 m3 which I chlorinated at 10 ppm free chlorine.
My question is theoretical:
if I had left the isolation valve on the 10 inch pipe to the Fire Fighting pumps open which is at the bottom of the tank, how fast will the chlorine diffuse into the pipe. there is no mixer.
rami
If you look at Table 1 in the attachment, you might be able to extrapolate a value from it.
