Formulate Diameter and Roundness
For example:
The drawing callout of the part has a diameter of 10.000 +/-.005"
Using CMM to measure this part:
Diameter 10.003"
Roundness is .011".
Does anybody know how these number formulate?
Diameter 10.003"
Roundness is .011".
RE: Formulate Diameter and Roundness
Is that "formulaic" enough?
I want to know how does the roundness "calculated" or obtained.
In addition, is that mean the diameter is the average result and the actual size become 10.003 +/-.0055?
Are you using ISO or ASME? That could make a difference about which one is the default algorithm.
John-Paul Belanger
Geometric Learning Systems
But is my interpretation correct?
-->that mean the diameter is the average result and the actual size become 10.003 +/-.0055?
I don't know what the intent is on that report of diameter. If that's the only number given then I'd question it. Maybe they mean that 10.003 is the maximum diameter -- trying to show that it's still within spec. But it's worth asking the people who provided that report, since it's not in a standard format that I know of.
John-Paul Belanger
Given that "roundness" is ISO term and ASME now has "circularity"
And who knows which standard the CMM follows? Sometimes it's own...
John-Paul Belanger
The size could be some sort of average, like least squares size. Then "roundness" tells us how far the part extends from that average.
I guess the only way is to ask CMM people exactly "how these numbers formulate?"
So the number of the diameter is average?
John-Paul Belanger
I am trying to remember my college metrology here. There are shapes that measure out to accurate diameters, that are way out of round. Try sketching out a three-lobed shape.
Is it possible your diameter was measured at one point, only?
JHG
The diameter was measured 12 points, uniformly distributed, using CMM.
I hope I interpreted correct: It seems for me that the diameter 10.003 is an average value. Roundness represents this result's bilateral tolerance.
I think I badly worded this subject...
