CONNECTOR TYPE=DCOUP3D missing properties
Hi guys, I have been trying to troubleshoot this problem for more that 3 hours without any success, can somebody highlight me on whats wrong with the model (attached .inp file).
When I try to check the model before the run, I get the error that two elements 2900 and 2901 have no properties assigned on them, which is not true cause I did assign the properties while creating the connector. I will appreciate your insight, thanks in advance.
RE: CONNECTOR TYPE=DCOUP3D missing properties
Users Manual 32.4.1 Distributing coupling elements
Remove them if you don't need them.
