Flush type clean out door height
Dear All,
For flush type clean out door of size 36" X 48" I am using an insert plate of 18 mm thick and 1747 mm height( 1372 + 375), and the adaject shell course thickness is 14.5 mm thick AND 2475 mm height . My question is there any requirement that says that height of insert plate for flush type COD be same as height of adjecent shell course height. In figure 5.12 of API 650 12TH Ed. at the top it says "nearest horizontal weld". What is the significance of this.
Inam
Inam
RE: Flush type clean out door height
I'm not sure if there is anything in the standard that specifically prohibits using an insert plate less than the shell course height, or of, say, stacking two 5' wide plates and welding into a 10' high shell course, but it's not the expected construction.
