Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Compliments on a fantastic web site. I have learned so much from my threads and even if sometimes I cannot solve the problem, it gives me the reassurance that I am not the only one putting up with it!..."
Geography
removing load bearing wall-how to tie ceiling joists
socrates0271 (Civil/Environmental)
15 Dec 02 18:33
If one is to remove a load bearing wall and replace it with a hidden beam in the ceiling that is perpendicular to the ceiling joists, what is the best way of tying those joists together so that they resist the spreading force of the roof above?
To further clarify, the joists will be cut so a beam can be dropped in and be flush with the ceiling.  The joists will then be hung from the beam with hangers.  the joists form the collar ties (so to speak) of the roof structure.  Is a strap sufficient, or something more elaborate?
ArchEngr (Structural)
16 Dec 02 9:56
Straps are usually sufficient, but detail to assure that the thrust is resisted during beam installation. Can the roof diaphragm provide temporary stability?
rlflower (Structural)
23 Dec 02 14:43
Yes, the strap looks like the most viable solution, but consider a couple of things:
There is a minor potential of slippage of the nails against the holes in the strap. The issue I am addressing here is only that of astetics: a crack would occur in a alongside the new beam because of this slippage (it does not take much for this crack to occur).
Perhaps this can be corrected by using pairs of PHD2s with threaded couplers attached to doubled ceiling joists at, say, 32 inches on center?
-Richard L. Flower, P. E.
Close Box
Join Eng-Tips® Today!
Join Us             Close
