NX9 how do I "simplify" a sheet body
I need help. I am trying to utilize the Global Shaping > By Surface type command. The attached data shows a simple single element sheet body in blue. The green sheet body contains tangent lines and facets. NX doesn't allow me to select a sheet that isn't a single element sheet as my Control Surface. The green sheet is just a small piece of the total part that I wish to deform my geometry on to. How can I revise or transform the green sheet into a usable/selectable sheet body for my Control Surface?
RE: NX9 how do I "simplify" a sheet body
The idea is NOT to change a simple surface to look like a complex one, but rather to modify a complex surface to match the shape of a more simple template type surface.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
OK, thank you for the information and part file example.
