Two-way coupling
Two-way coupling
Good morning. I'm working with Workbench V.16.0, and I have a question about the Coupled-field analysis; I'd like to know if, eventually, is possible and how to execute a two-way coupling between the thermical field and the structural field.
My work consists in two bodies initially situated in contact, which are at two different temperatures; under some load conditions, one of them pushes against the other. I'd like to evaluate simultanously both the thermical and structural evolution. I wonder if that is possibile ,working in "static Structural", setting in the "APDL module" a thermic contact between two bodies, which describes the heat conduction, putting some code lines in the "command line" of Workbench.
