CATPart Conversion
CATPart Conversion
I need to convert a CATPart from V5-6R2013 to V5R20. I accidentally saved a V5R20 file using V5-6R2013. A customer can only view and work with the CATPart using V5R20. Thanks to anybody that can help.
RE: CATPart Conversion
you'll never get the full parametric part in r20 (unless you do the work again)
Try Tools > Utility > DownwardCompatibility
Drew Mumaw
http://www.textsketcher.com/
http://www.drewmumaw.com/
Ctrl+F to search and type in catiav5 and the first result should show you the version.
Thanks.
