How to setup ug_convert_part batch file on Windows 7
Referring back to this slick right click on the prt file to convert units method: http://files.engineering.com/getfile.aspx?folder=c... How does one set this up now in Windows 7 or later since there is no longer a File Types tab in the Folder Options dialog?
RE: How to setup ug_convert_part batch file on Windows 7
Below is the code, copy & paste into a empty text file, save it, then rename the extension to .bat
Run it by double clicking and as long as you have admin rights, it will update the registry entries for NX part types.
CODE -->
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
I cannot remember how I did it, I'm assuming it was from something someone posted on the old bbs board.
