EPANET Operation manual
I've recently been tasked with modelling an existing municipal water distribution system using EPANET. I have managed to draw up the pipe network and nodal demands with relative ease after simply following the basic user manual, however I now need to input the current pumps and rules that co-ordinate their operation. I have found very little help available to do this slightly more advanced work, and I am struggling to successfully run the results.
Is anyone aware of a users manual that provides more thorough help and guidance than the standard manual that is issued online?
RE: EPANET Operation manual
bentley advanced water distribution modeling and management
If you don't have any Bentley software legitimately you can sometimes get lucky using a google search for free PDF download of this reference manual which explains this very well.
The most appropriate method would be to obtain a fire hydrant flow test and use that data to model a three point pump curve which will give you data to enter into epanet
I appreciate your help,
Tait.
