Unnecessary lines in drafting
Hi all,
I was creating a drawing of an assembly in NX. The Jt part in assembly when projected as a view shows multiple lines on surface by default making the part as black object while other NX parts are visible clearly like they should.
Any solution?
Any solution?
Shetty,
Newbie
Using NX 10.0.1.4
RE: Unnecessary lines in drafting
Shetty,
Newbie
Using NX 10.0.1.4
And I figured the solution to my second comment. It was the filters/checkboxes that I had to use present around hidden lines option in render sets.
Shetty,
Newbie
Using NX 10.0.1.4
