How hard is it to get an entry-level chemical engineering position?
I came from a non-traditional background. And I was curious if any chemical engineers, experienced in the field, would be able to offer any advice. How can I go about getting an entry-level job in chemical engineering and how likely is it?
A little bit on my background. I am a graduate of MIT with a bachelor's in neuroscience and minor in chemistry. I switched fields to chemical engineering and am currently undertaking my final year of a master's degree at the University of Maryland: College Park. My cumulative GPA is 3.46/4.00. I have a concentration in mechanical engineering, and I should have a paper in biomaterials published by the end of the academic year. I have no industry experience. Nor do I know how to go about getting an internship.
What sectors are my best bet for hiring? Should I focus on biochemical/biomedical engineering? Am I still eligible for more traditional chemical engineering occupations such as oil and gas? Although my background does not emphasize petroleum engineering, can the versatility of my background still have me hired at a great company like Schlumberger? Will companies scoff at my non-traditional background (i.e only 2 years of hardcore chemical engineering courses)? Or can I use it to my benefit? When are the best times to apply (as I hear hiring seasons are very cyclical)?
And also, do I need an internship to vastly increase the competiveness of my application? My time in lab is sort of like a full-time job. I often have to balance that with the rigors of schoolwork. And my research should lead to industrial applications (albeit in materials).
But if I do need an internship, what can I do to go about getting one say for January or next summer? Will I look over or underqualified in my resume?
And finally, what are the most important things that I can do separate myself from the thousands of other qualified candidates applying to chemical engineering positions? I am really invested in becoming an engineer.
RE: How hard is it to get an entry-level chemical engineering position?
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
@Latexman Thank you for your advice.
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
