Can I get chemical engineering job with a master's degree but no bachelor's?
I am a nontraditional applicant with a bachelor's degree in neuroscience. I am almost finished a master's degree in chemical engineering, but many jobs that I wish to apply to have a "bachelor's of engineering" as a requirement. And a master's as only a "preference." Would these companies still be willing to consider me? If I have a master's in the field, but no bachelor's, do I fulfill the bachelor's requirement or am I automatically kicked out of the applicant pool?
RE: Can I get chemical engineering job with a master's degree but no bachelor's?
There may be some issues in whatever coursework you might have missed, like O-chem and thermo? Unless, you took them as part of your master's program
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
No, I actually finished all those prerequisites. 3 semesters of o-chem, 2 of thermo, 2 of fluid, etc... and am now taking more advance courses such as finite element analysis. Should I be ok then?
If I were you I'd take (and hopefully pass) the FE exam. This will rather redundantly demonstrate that you have covered some, perhaps even enough, of the usual BEng material.
Cheers
Greg Locock
I would imagine the vast majority of job postings are written with minimums in mind... Bachelor's degrees, for example. They would "prefer" applicants have advanced degrees as the position likely requires advanced skills. But I have a hard time thinking an interviewer would even recognize you didn't have a Bachelor's after seeing the Master's listed, let alone dismiss you from the candidate pool because of it.
Dan - Owner
http://www.Hi-TecDesigns.com
The folks who place employment ads requiring candidates to have bachelors of engineering may want to join in on this discussion. Please include a link with your resume/cover letter.
Why even stop to ask? Who's permission do you need to apply?
I notice people with Masters who are missing their undergrad engineering training. But in a specialist job you might be OK.
