High emissivity coatings for furnaces
Above 1400 F heat transfer by radiation is greater than by convection, During radiative heat transfer, energy is transmitted from a refractory wall at higher temperature than the metal part to be heated. Generally the emissivity of the refractory is less than 0.8. NASA has developed high emissivity coatings which has emissivity of 0.9. Some coatings formulations are now available to coat the refractory walls and reduce fuel consumption. We plan to apply this coating in a steel reheating furnace, and would like to know if others have used such coatings, the precautions to be taken, and the percent reduction in energy consumption.
RE: High emissivity coatings for furnaces
Note that a high emissivity means that it will absorb all the radiated emission, and only emit a lower temperature version of what came in.
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
