Nonlinear modal time history analysis
I know that I can see all axial load by clicking the display--> show force/stress-->frames. And I can see the results from time history analysis by choosing the time I want. I tried to find the tables that provide how the forces change with each time steps but I can't. I tried in the display--> show tables option. But I cannot find it. It only shows the max and min force at different station for columns. Is there anywhere in Sap can show the force versus time tables? Thank you!
RE: Nonlinear modal time history analysis
Show Tables > Modify/show Options > Multi-Values Response Combos > "Multiple values, if possible" (or step-by-step results depending on your SAP version.
