Pole slipping of synchronous machines
Hi all,
Just wondering whether synchronous machines can pole slip for 2 phase faults at all?can anyone help please?
RE: Pole slipping of synchronous machines
It depends on what is the fault clearance time. If it is a bus fault which is cleared with in the system Critical Clearing Time (CCT, which could be as low as 100 ms), then pole slip may not occur.
The transient stability study report would give you a clue.
