using abaqus to simulate simply supported glulam beam under blast load
hello friends
i am doing simulation by abaqus on glulam beam with dimensions 2500*228*80 mm GL24h i have already built the model but i could not run it because i could not or would not being able to define the glue between parts of the glulam beam so please is there any one professional can help me to run the attached file as soon as possible and send me key-ward file as well as the results to this Email (jalalnasseb@yahoo.com)
Actually, i am studying the response of glulam timber subjected to blast load however in this example i used uniform load on simply supported beam .
i am looking forward to hearing from you soon
THANKS
JALAL
