Theodilite set up errors
Can anyone explain why when setting up a theodolite you should not sight control points that are on a direct line between each other and the theodolite, i.e CP1 = 0o and CP2 = 180o.
I know doing this is likely to result in an error, but im struggling to work out why.
Any advice much appreciated.
LB
LB
RE: Theodilite set up errors
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
