Import from MDT6
Import from MDT6
Which way (format) is the better to import from MDT6 the solid models without errors ( or minimal).
Thank you.
Thank you.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Import from MDT6
I think the best solution is to try with IGS format (cel putin in SW97 era cea mai buna solutie).
Fernando
(Multumesc, cum ai ghicit?)
When you try to import a solid model from a software to another is almost impossible to have all the features of that model. For example, when you will import from IGS format in CATIA, you will be able to read only primitive solids, b-splines but without surfaces (and I think you cannnot know also the topology of the solids).
I suppose that its the same problem in SW (as I remember, for the time beeing, its also a Dassault product).
Maybe somebody can give us a little bit more informations about that (fer@xnet.ro).
Fernando
Please report this to your reseller. If you have errors with the MDT translator, they may be able to fix this in a Service Pack.
cheers,
Joseph
I haven't had any experience with mdt6 files, but lots with mdt5. I've found the best avenue was exporting from mdt5 as an acis file *.sat, then importing into sw.
Another avenue would be to use Pro-Desktop express (free download) which imports dwg, iges, step, and sat, then export to step, medusa, iges. www.ptc.com This program has saved me alot of grief over the past year working between sw & mdt.
Happy Holidays all
Merry Christmas
Merry Christmas and a Happy New Year to all (un An Nou cu bucurii).
Fernando
