DEFINING RENDER SETS
Under Preferences - Drafting - view - common - generak, there is a button for Define.
When we go to this, the settings are often not what we would like. We would like the line thickness set as thin, and dashed for instance. Is it possible to set these up in defaults? I cannot find them in customer defaults.
If not, is it possible to write a journal that will change these? When I record journals, they dont seem to work for these settings.
RE: DEFINING RENDER SETS
To set the line weights and fonts for view geometry in the customer defaults, go to: Drafting -> general -> standard -> customize standard -> view -> {set the line font and weight in various tabs such as visible lines, hidden lines, detail, etc}.
www.nxjournaling.com
