Dowel into rock for sliding resistance
If placing a dowel into rock for sliding resistance, (basically shear) do you have them just grout in, or epoxy, or just hammer the heck of of them into a tight hole?
RE: Dowel into rock for sliding resistance
https://www.google.com/search?q=rock+anchors&i...
BA
BA
Talk with a good geotechnical engineer. There's an actual methodology to designing the rock anchors. You have to take into account both local and global failure modes. Tiebacks to resist sliding are typically angled back so that they primarily act in tension. I guess you'd get some dowel action from a vertical bar, but it would probably be less reliable than a bar acting in tension. I think the geotechs would frown on it. If that's your concept, why not just use a shear key like azcats said?
They are not tiebacks in my mind, just a dowel to resist the balance of sliding resistance I need to make it work. No tension. A #5 bar, drilled and grouted about 12" into the rock.
I cant get them to give me a capacity of the the rock, and they dont want to chip away at the rock to provide a keyway. Its a contractor trying to do it as cheap as possible.
you might find more information here:
http://www.williamsform.com/Ground_Anchors/ground_...
suggest spin lock or resin anchors
