Unknown spring support ?
Greetings,
This is my first post, so please be gentle
. We are planning a one-to-one replacement of a topside flowline due to internal corrosion. A spring support will also have to be replaced, but unfortunately we do not have any documentation on it. All we have is a name plate and a serial number, but nobody inhouse seems to know the manufacturer or brand COMET ? We are hoping the manufacturer can find the spring support data via the serial number so we can order an identical unit, and avoid using additional engineering resources. The spring support is originally from 2002 or thereabouts. If anyone of you know the manufacturer of this COMET spring support and where to contact them that would be greatly appreciated.
http://files.engineering.com/getfile.aspx?folder=7...
http://files.engineering.com/getfile.aspx?folder=1...
Jakob Molholm
Jakob Molholm
RE: Unknown spring support ?
What I would do a it a new stress analysis of the line, so you can design a new spring support to the current operating conditions and process environment of the line. Get a decent support from Lisage and the likes, theyll outlast this one, as this design of the current one is just wrong. With a 1-to-2 replcament you'll risk a support failure in the near future.
Second, I would check all current supports if theyre the same as this one. If they are, its matter of time before something's about to happen.
Where are you located? And do you have a few more pictures?
Jakob
"'Bergen Pipe Supports' supports are listed under the name ‘Comet’ (this used to be our brand name)."
http://www.pipesupports.com/engineering/software
Piping Design Central
Jakob
Jakob
