nx requires id_server feature in license file
I have installed NX 6.0. then after a month I have installed NX 8.0 but i encounter this problem. when i open my nx 8.0 it says "NX REQUIRES ID_SERVER FEATURE IN LINCENSE FILE" can you pls help me?..
RE: nx requires id_server feature in license file
Are you using a license file for NX8?
Did you update the license service (if you're using one) to the one that comes with NX8?
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
