Bottom up mesh
Bottom up mesh
Hi All,
I'm trying to mesh a turbine but I am unable to get the blades to mesh. I got an error saying that I had to generate a bottom-up mesh. However, when I generate the bottom-up mesh I get the following: See attached. I then try the extrude method for bottom-up mesh but the mesh does not follow the profile of the blade. Any ideas?
Jer
Jer
RE: Bottom up mesh
RE: Bottom up mesh
Sorry for the late reply.
I have been trying to use brick elements using the create bottom up mesh method but I get this error around the trailing edge. Any idea why this is occuring?
Jer
