Annular plate projection
Hello everyone,
My question is, what is the maximum projection from the tank shell that an annular ring should be? I found in API-650 Sec. 5.4.2. that the minimum should be no less than 2 inches but not finding a maximum.
RE: Annular plate projection
There is no maximum.
"at least 2 inches", no maximum.
thank you both! The more I asked around, I found that out.
