Smoke detector for high ceilings
I have a query concerning installation of a smoke detector in area of 16' high ceilings. Would the same installation requirements be applicable as for regular 7' ceilings or are they required / preferred to be wall mount at lower heights to allow for accurate smoke detection?
Thank you.
RE: Smoke detector for high ceilings
You may want to red-flag this posting and repost in forum184: NFPA (fire) Code Issues
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Smoke rises, hot air rises.
Bill
"Why not the best?"
Jimmy Carter
katwalatapan,
I think the best thing to do is ask AHJ.
NFPA 72-2016 (alarm systems) is now out and for sale. I heard that supposedly a lot of major changes from 2013.
Good luck,
Dave
If you put them on the wall at 7 feet, they _might_ go off before the flashover.
Mike Halloran
Pembroke Pines, FL, USA
