[Function] Demonstrate that two planes are equal
Hi everyone,
I struggle to create a function that allow to determine whether or not two planes are parallel and on the same level. Bellow I managed to get the angle between the two planes and the idea is to return true or false in fonction of the angle between them. However, I don't know how to handle the case when the two planes are paralalel but not on the same level. Any idea ?
Function AngleBetweenPlanes(oFirstPlane, oSecondPlane)
Dim reference1 As Reference
Set reference1 = oPart.CreateReferenceFromObject(oFirstPlane)
Dim reference2 As Reference
Set reference2 = oPart.CreateReferenceFromObject(oSecondPlane)
Dim TheSPAWorkbench As Workbench
Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench")
Dim TheMeasurable As Measurable
Set TheMeasurable = TheSPAWorkbench.GetMeasurable(reference1)
Dim MinimumDistance As Double
MinimumDistance = TheMeasurable.GetAngleBetween(reference2)
MsgBox ("Angle=" & CStr(MinimumDistance))
End Function
RE: [Function] Demonstrate that two planes are equal
get the distance to (0,0,0)
Eric N.
You mean set the two planes origins to (0,0,0) ? If yes, it will work but my function won't tell me if the two planes are on the same level...
thanks ferdo for reading between my missing line
Eric N.
I'll try tomorrow at work and tell you what come up
Another way:
Calculate and compare the A,B,C,D coefficients of both planes. (Ax + By + Cz + D = 0)
sorry for the late answer.
It is really frustrating, my angle function doesn't work anymore. @itsmyjob I can't even try to get the distance to (0,0,0)...
@jackk I am really new to VBA, I don't really know from where to start to get the planes equations and then compare coefficients...
So here is my code.
What the code do : During a loop, you have to select a circle edge of a body part and then it create a reference plane based on this circular edge.
What I need to do : create a new reference plane if the next circular edge is not on the "same plane". For that I need my function that allow me to compare planes...
Any ideas ?
CODE -->
Option Explicit
Sub CATMain()
' Variables declarations
Dim oPartDoc As PartDocument
Set oPartDoc = CATIA.ActiveDocument
Dim oSelection
Set oSelection = oPartDoc.Selection
oSelection.Clear
Dim oPart As Part
Set oPart = oPartDoc.Part
Dim oBodies As HybridBodies
Set oBodies = oPart.HybridBodies
Dim oParams As Parameters
Set oParams = oPart.Parameters
Dim oHybridShapeFactory As HybridShapeFactory
Set oHybridShapeFactory = oPart.HybridShapeFactory
Dim oProduct As Product
Set oProduct = oPartDoc.GetItem(oPart.Name)
Dim oPublications
Set oPublications = oProduct.Publications
Dim InputObjectType(0)
InputObjectType(0) = "Edge"
Dim j As Integer
Dim i As Integer
Dim m As Integer
' Circular holes prerequisite
    Dim oHolePublicationData As HybridBody
    Dim strHybridBodyName As String
    strHybridBodyName = "HolePublicationData"
    Dim oReferencePlane
    Dim ReferencePlaneForObject As Reference
    Dim oLine
    Dim oClearanceCircle
    Dim oDiamRelation As Formula
    Dim oExtractPointParam
    Dim oClearanceDiamParam As Dimension
    Dim dFootThickness 'As Double
    Dim oLineParams As Parameters
    Dim oFootThickParam As Dimension
    Dim dCircleRadius As Double
    Dim dInsertHoleDiamParam
    Dim bInsertHolesParamExistence As Boolean
    bInsertHolesParamExistence = False
    oPart.Update
'Creation of HolePublicationData geometrical set and parameters if previous checks ran well. Ask the user to enter the FootThickness as well.
        Set oHolePublicationData = oBodies.Add()
        oHolePublicationData.Name = strHybridBodyName
        oPart.Update
' "Circular holes interface"
    MsgBox "Circular holes interface starting; press escape when you have finished."
    ' Declaration of variables needed for the "Circle interface" below
    Dim CircularHolesStatus
    CircularHolesStatus = "Normal"
    Dim oSelectedCircle
    Dim iHoleNumber As Integer
    Dim strHoleNumber As String
    iHoleNumber = 1
    Dim oCircleCenter
    Dim ReferenceCircleCenterForObject As Reference
    ' Circular holes selection
    While CircularHolesStatus = "Normal"
        'Error-handling
        On Error Resume Next
            If Err.Number <> 0 Then
                Err.Clear
                MsgBox "Unable to proceed.", vbCritical, "Critical error"
                Exit Sub
            End If
        ' Selection of the circle edge
    ' Line from where it resume if an other edge than a circular is selected
SelectionResumption:
        oSelection.Clear
        CircularHolesStatus = oSelection.SelectElement2(InputObjectType, "Select a circular hole edge ", False)
        If CircularHolesStatus = "Normal" Then
            Set oSelectedCircle = oSelection.Item(1).Value
            oSelection.Clear
            If Not TypeName(oSelectedCircle) = "TriDimFeatEdge" Then
                MsgBox ("The selected object is not a slotted edge, please start again.")
                GoTo SelectionResumption:
            End If
            'Create the reference plane and publish it.
                Dim FirstOne, SecondOne
                Set oReferencePlane = oHybridShapeFactory.AddNewPlane1Curve(oSelectedCircle)
                oHolePublicationData.AppendHybridShape oReferencePlane
                oPart.Update
                oReferencePlane.Name = "Ref.Plane" & CStr(iHoleNumber)
                Call Publication(oReferencePlane, oProduct)
                oPart.Update
                oSelection.Clear
                oSelection.Add oReferencePlane
                oSelection.VisProperties.SetRealColor 128, 0, 128, 0
                oPart.Update
                oSelection.Clear
               Set ReferencePlaneForObject = oPart.CreateReferenceFromObject(oReferencePlane)
               oPart.Update
               'This is to number every points, lines and clearance circle
               iHoleNumber = iHoleNumber + 1
               strHoleNumber = CStr(iHoleNumber)
'Here is the test I want to do
If iHoleNumber = 3 Then FirstOne = oHolePublicationData.Item("Ref.Plane1") SecondOne = oHolePublicationData.Item("Ref.Plane2") Dim reference1 As Reference Set reference1 = oPart.CreateReferenceFromObject(FirstOne) Dim reference2 As Reference Set reference2 = oPart.CreateReferenceFromObject(SecondOne) Dim TheSPAWorkbench As Workbench Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench") Dim TheMeasurable As Measurable Set TheMeasurable = TheSPAWorkbench.GetMeasurable(reference1) Dim Angle As Double Angle = TheMeasurable.GetAngleBetween(reference2) MsgBox ("Angle=" & CStr(MinimumDistance)) End If Else If MsgBox("Have you finished to prepare all the circular insert holes ?", vbYesNo) = vbNo Then CircularHolesStatus = "Normal" Else MsgBox ("Circular holes interface completed") GoTo CircularWhileExit: End If End If On Error GoTo 0 Wend CircularWhileExit: End Sub
Arf, can't find any solution. It seems that whatever I change it will not work. I might made a mistake in my logic. What do you think ?
For those interested, here is a solution :) !!!
CODE -->
Function IsTheSamePlane(oFirstPlane, oSecondPlane) As Boolean
    ' ABSTRACT:
    ' Check if two planes are identical.
    ' DEPENDANCIES:
    '   IsInThePlane
    Dim i As Integer
    Dim arrFirstPlaneOrigin(2)
    Dim arrFirstPlaneFirstAxis(2)
    Dim arrFirstPlaneSecondAxis(2)
    oFirstPlane.GetOrigin arrFirstPlaneOrigin
    oFirstPlane.GetFirstAxis arrFirstPlaneFirstAxis
    oFirstPlane.GetSecondAxis arrFirstPlaneSecondAxis
    IsTheSamePlane = False
    Dim arrPoint1(2)
    Dim arrPoint2(2)
    'Creation of two points having key coordinates for the test, more precisely Point1 (resp. Point2) on the first plane first axis (resp. second axis).
    For i = 0 To 2
        arrPoint1(i) = arrFirstPlaneOrigin(i) + arrFirstPlaneFirstAxis(i)
        arrPoint2(i) = arrFirstPlaneOrigin(i) + arrFirstPlaneSecondAxis(i)
    Next
    'Test if the first plane origin and the two previous points are in the second plane
    If IsInThePlane(arrFirstPlaneOrigin, oSecondPlane) Then
        If IsInThePlane(arrPoint1, oSecondPlane) Then
            If IsInThePlane(arrPoint2, oSecondPlane) Then
                IsTheSamePlane = True
            End If
        End If
    End If
End Function
Function IsInThePlane(oPoint, oPlane) As Boolean
    ' ABSTRACT:
    ' Check if a point is in plane.
    Dim arrPlaneOrigin(2)
    Dim arrPlaneFirstAxis(2)
    Dim arrPlaneSecondAxis(2)
    Dim arrPlaneNormal(2)
    Dim Value As Double
    oPlane.GetOrigin arrPlaneOrigin
    oPlane.GetFirstAxis arrPlaneFirstAxis
    oPlane.GetSecondAxis arrPlaneSecondAxis
    arrPlaneNormal(0) = arrPlaneFirstAxis(1) * arrPlaneSecondAxis(2) - arrPlaneFirstAxis(2) * arrPlaneSecondAxis(1)
    arrPlaneNormal(1) = -arrPlaneFirstAxis(0) * arrPlaneSecondAxis(2) + arrPlaneFirstAxis(2) * arrPlaneSecondAxis(0)
    arrPlaneNorm0al(2) = arrPlaneFirstAxis(0) * arrPlaneSecondAxis(1) - arrPlaneFirstAxis(1) * arrPlaneSecondAxis(0)
    Value = arrPlaneNormal(0) * (oPoint(0) - arrPlaneOrigin(0)) + arrPlaneNormal(1) * (oPoint(1) - arrPlaneOrigin(1)) + arrPlaneNormal(2) * (oPoint(2) - arrPlaneOrigin(2))
    If Value < 0.001 And Value > -0.001 Then
        IsInThePlane = True
    Else
        IsInThePlane = False
    End If
End Function
Hope I will share again with all of us.
Pharys
