Applying loads in loadsteps and displacement condition at end of loadstep
All,
Need some help with the following, I am using Ansys V16 Workbench en I wanted to apply loads in the first three loadsteps and the final 4th loadstep I want to apply a BC (displacement = 0 mm).
You can insert a table for the displacements as well, however I cant put the first 3 steps in "FREE'.
How could I do this, without having to actually define contacts between two objects? Is this actually possible?
The model: Its a pipe which is bended and afterwards its supported. I don't want to model the supports if not really nescessary
. That's why I hope I can use somekind of BC.
RE: Applying loads in loadsteps and displacement condition at end of loadstep
