Buried Power Lines
Buried Power Lines
Two questions about buried power lines: 1)Is the depth of such power line to be below the frost lines? 2) since there will be some heavy truck traffic over this power line and I expect that the soil will be saturated with storm water and snow melt, what would be the suggested protective casing material thru which this power line will be laid .
RE: Buried Power Lines
For the National Electric Code, the depth of the line depends on voltage,if under 1000 volts a could bet is 24" is the minimum and for truck traffic is the same. In most jurisdictions require conduit for traffic. Check with the local AHJ and power utility for both questions.
Hope this helps;
Dave
For the power cables there are no such arrangement as standard. If such special requirement is there, it shall be engineered to address the specific issue.
Hope this helps;
Dave
Frost heave may be an issue, or with plastic conduit, it may not. The depth of the power lines may also be dictated by soil conditions, such as rock, or water table, or if placed in a common corridor may be just below the sidewalk.
