(VBScript) Without the Selection, How to Add Bodies on the Product?
Hello, Guys
I think this is very simple script, but I can't make it.
I made a script to add bodies on Product, not open the window a part.
Of course, I can make it with the selection.
But I don't know how to add bodies without the selection on the Product.
Could you check below my scripts?
The first script is with the Selection, the second script is without the selection.
CODE --> VBScript
Sub CATMain()
Set Selection1 = CATIA.ActiveDocument.Selection
Set Selection2 = Selection1.Item(1).Value
Set partDocument1 = CATIA.Documents.Item(Selection2.Name+".CATPart")
Set part1 = partDocument1.Part
Set bodies1 = part1.Bodies
Set body1 = bodies1.Add()
part1.Update
End Sub
CODE --> VBScript
Sub CATMain()
Set partDocument1 = CATIA.Documents.Item(1)
part1.Update
End Sub
RE: (VBScript) Without the Selection, How to Add Bodies on the Product?
Hi Ferdo. I'm working in a Product not in a CATPart.
Hi, Ferdo, Thank you for your reply.
Yes, I know what you mean..
But I thought the new way to do it..
If you are working in a product, how do you know documents.item(1) is a part in that product? Document 1 could be the product, and your macro will fail.
If the first item in the product is a part, you could set the part like this:
Set product1 =Catia.activedocument.product
set part1 = product1.products.item(1).parent.part
Item(1) is the instance level of the first part
.parent is the document of the first part
.part is the part
Hi, lardman
I tried with your code.
But it doesn't work.
Can you check my code?
CODE --> VBScript
Set product1 = CATIA.Activedocument.product
Set part1 = product1.products.item(1).parent.Part
'Set partDocument1 = CATIA.Documents.Item(1)
'Set part1 = partDocument1.Part
part1.Update
