NX Journal filepath
NX Journal filepath
Dear all,
i have a question about a journal that i have found.
I want to place the file location into a part attribute.
this so i can use this attribute to controle a ug_excel_read expression.
This part is changed from location when there is a save as action been done.
now i can created with the journal the complet filepath but i want to cut off the .prt
how can help me with this.
Below the script.
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.UF
Module NXJurnal
Dim theSession As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Sub Main
workPart.SetAttribute("File_Path", GetFilePath())
Dim user_name As String = System.Environment.ExpandEnvironmentVariables("%username%")
workPart.SetAttribute("Name", user_name)
End Sub
Function GetFilePath()
Dim strPath as String
Dim strPart as String
Dim pos as Integer
'get the full file path
strPath = displayPart.fullpath
GetFilePath = strPath
End Function
End Module
already thanks
Ruud
Below the script.
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.UF
Module NXJurnal
Sub Main
End Sub
Dim pos as Integer
End Function
End Module
already thanks
Ruud
RE: NX Journal filepath
CODE
Option Strict Off Imports System Imports NXOpen Module Module41 Sub Main() Dim theSession As Session = Session.GetSession Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Dim strPath As String = theSession.Parts.Work.FullPath lw.WriteLine("strPath: " & strPath) 'remove the last 4 characters of the path Dim strPath2 As String = strPath.Substring(0, strPath.Length - 4) lw.WriteLine("strPath2: " & strPath2) Dim strFile As String = IO.Path.GetFileName(strPath) lw.WriteLine("file name with extension: " & strFile) Dim strFileNoExt As String = IO.Path.GetFileNameWithoutExtension(strPath) lw.WriteLine("file name without extension: " & strFileNoExt) Dim strDir As String = IO.Path.GetDirectoryName(strPath) lw.WriteLine("strDir: " & strDir) End Sub End Modulewww.nxjournaling.com
