How to make a software portable ?
Like to know how to make a software portable ?
Example i have photo shop portal file so without installing i can run it.
Careerarm
RE: How to make a software portable ?
You should probably find a Photoshop forum for this sort of question
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
If you want to make your software (coding) portable, you have to look at established standards and good practices first. Then you start with your datasets, massaging them to conform. Then you consider making your sacred code inner loops kind of problem & solution libraries, or you leverage established libraries. At this point your employer may ask, is there anything left. A good employer will ask, where did this take us. The point here attempts to be, think of what "portable" means, where exactly do you want to take it? Who else is there? Can they offer some assistance? "Portability" is a philosophical question before any programming in any particular language or any data design in any particular paradigm comes into play.
